Hi guys, so when doing an inverter installation where the main db on ground floor is 3 phase as well as the dB on the 1st floor is 3 phase, how would you go about separating the circuits especially working with the neutral when the inverter must work on one of the phases only for example the blue phase and it must feed a couple plugs and lights downstairs and upstairs? Would you pull a separate cable for the upstairs dB and have it connected on the output side of the inverter? Sans only has diagrams for single phase installations and I’d like to get your views on this. What happens when you don’t run a separate cable for the couple circuits for the upstairs db that must be on the inverter and what happens with the Neutral? My thinking with pulling another 2 core + earth for the couple circuits would then be to put it in its own little db next to the upstairs db making it easily identifiable as to what circuits are on feeding via the inverter with the circuits in the downstairs db.
What is your take on circuits in a db board running through alternative power and it being clearly identifiable? Would you rather put it in its own little db next to the existing db or keep it in the existing db and just label it properly? Finding the neutrals in an existing db is a nightmare
